Phone Replacement
Dear Team,
We are replacing old phones with the new IP phones 7975.Please advise, how to replace phones in production environment with same extension and all information?
Phone Replacement
Hi Waqas,
How many phones you have to replace?
From which model to which model?
What version of CUCM you are using?
Nishant Savalia
Regards, Nishant Savalia
Phone Replacement
@ Nishant
How many phones you have to replace?        1100
From which model to which model?              7940,7945,etc to 7975
What version of CUCM you are using?           CUCM 9.1
Re: Phone Replacement
Hi Waqas,
TAPS is a commonly used method for the bulk provisioning of phones in an enterprise. It is used alongside the BAT in order to provision new phones in the enterprise. For example, if you must add 10,000 new phones to an enterprise, you have these options:
  • You can add each phone manually.
  • You can enable auto registration. Once the phones are registered, you can manually configure each phone.
  • You can use the BAT in order to configure the phones, but you must also add the MAC addresses of 10,000 phones in the.csv file.
  • You can use the BAT with dummy MAC addresses, but use TAPS in order to configure the phones.
The best way to replace large amount of phones is to use TAPS along with BATS provided you have UCCX.
Please refer below links for detailed instructions.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/bat/9_0_1/CUCM_BK_C22BD805_00_cucm-bulk-administration-guide-90/CUCM_BK_C22BD805_00_cucm-bulk-administration-guide_chapter_01001010.html
http://www.cisco.com/c/en/us/support/docs/customer-collaboration/unified-contact-center-express/116817-configure-product-00.html
Nishant Savalia
Phone Replacement
@ Nishant Savalia
We dont have UCCX .Please advise, how to export  cucm data (name,extentions,partitions) to CSV file for new phones instead of typing one by one.
Phone Replacement
Use BAT
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
+5 Java.
Navigate Bulk Administration --> Phone -> Export Phones and choose "all phone details"
In this way you have all the info you need about ip phones to substitute and you can manipulate the cvs files to than reimport it with new phones.
Carlo
Please rate all helpful posts "The more you help the more you learn"
231
