Phone rings over PRI but no voice on answer
I am installing a cisco voice GW 3845 with a PRI circuit . The gateway registers wih the CCM ok and we can make onnet call in the same region and between regions as well.
When i call over the PRI either incoming or outcoming the phone rings in both ends but the voice does not quick in.
I checked all the PRI parameters, controller and everything is ok.
I also check with a sniffer and i can mirror the ohone port and i can see the RTP traffc going through in the right vlan and in both ways.
Isdn q931 also is ok.
Auto QoS is enable
Can someone please help ?
1 REPLY
Re: Phone rings over PRI but no voice on answer
Do you have MGCP bound to an interface?
check and see if you have the following statements under your mgcp config:
mgcp bind control source-interface [interface you would like to bound mgcp to, usually loopback or ethernet]
mgcp bind media source-interface [interface you would like to bound mgcp to, usually loopback or ethernet]
Hope that helped.
124
