Phone services not showwing into jabber
The phone services are not appearing into jabber 9.2.x version
Do you have any ideas?
The deskphone control is working but the softphone not
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
  • IP Telephony
1 ACCEPTED SOLUTION
Config this in the .xml you're using
CUCM>
Not_Set
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hall of Fame Super Silver
What services are you referring to?
For sotphone not working, do you have CSF configured properly and associated properly?
Chris
Hi Chris
Into the jabber is one tab calling Phone services which you will config ip and credentials of teh user(but now its not appear there)
CSF and all the associations are configured correctly
Chrysostomos
CUCM>
Not_Set
java
java
191
