Phone showing Different Time (UTC Time Zone ....Not NTP Time Zone)
I have noticed that Few Phones are taking UTC Time Zone From the CUCM not taking the NTP TIME. Please provide your valuable comments.
CUCM Version 8.6.2.21900-5
Added the NTP status from the Both Servers...
admin:utils ntp status
ntpd (pid 28138) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
127.127.1.0     .LOCL.          10 l   30   64  377    0.000    0.000   0.001
*10.10.2.2       64.250.229.100   2 u  954 1024  377    0.615   -2.633   0.658
+10.10.2.3       64.250.229.100   2 u  864 1024  377    0.632    1.574   0.059
synchronised to NTP server (10.10.2.2) at stratum 3
   time correct to within 64 ms
   polling server every 1024 s
Current time in UTC is : Sun Aug 10 08:34:47 UTC 2014
Current time in Asia/Dubai is : Sun Aug 10 12:34:47 GST 2014
ntpd (pid 27097) is running...
127.127.1.0     .LOCL.          10 l   39   64  377    0.000    0.000   0.001
*10.10.17.21     10.10.2.2        3 u  169 1024  377    0.384    0.825   0.056
synchronised to NTP server (10.10.17.21) at stratum 4
   time correct to within 80 ms
Current time in UTC is : Sun Aug 10 08:35:36 UTC 2014
Current time in Asia/Dubai is : Sun Aug 10 12:35:36 GST 2014
admin:
admin:
Did you check the DatTime
Did you check the DatTime group assigned to phone in call manager?
if you manipulate setting therer, does that reflact your phone?
regards
Chintan Gajjar
VIP Purple
Is this happening for one
Is this happening for one particular IP phone model ?
regds,
aman
Hi,Till now i have noticed
Till now i have noticed that its happening only with particular Model IP Phone and with Few Users only.
Silver
 I have solved a lot of time
I have solved a lot of time differences on phones by upgrading the firmware, or applying DST updates on CUCM.
It seems Cisco has some difficulties displaying time correct on different models of phones connected to different versions of CUCM.
Especially during Summer-time Winter-time  :)
Hi,Settings are properly
Settings are properly assigned to the Phone. Regarding the Manipulation, since phones are located at Remote Location, i wont be able to do much R&D on the same and as mentioned its reported only with particular Locaion and Few 7945 IP Phone Models only.
what time zone you are using
what time zone you are using in Date time group, and waht is the load version of the phone?
and what is your CUCM version?
regards
Chintan
I have resolved the
I have resolved the particular issue, my end customer has forgot to add option 150 in their DHCP Server. After adding the option i have restarted that phone and issue got resolved.
Thanks to all for your support.
657
