phone with 2 lines
                   hi,
on this phone I have line 1 ext: 41211. so when I push the voicemail button on the phone it goes to unity for this extension.
all works well.
on this same phone I have lines 2,3,4,5,6 with ext: 41210. (this is a reception phone so we can get many calls on the same extenstion).
all this works well too.
ephone-dn  6
number 41210 no-reg primary
label 41210
description User One
name User One
preference 1
call-forward noan 41399 timeout 10
no huntstop
ephone-dn  7
label 41210
name User One
preference 2
no huntstop
ephone-dn  8
label 41210
name User One
preference 3
call-forward busy 41399
no huntstop
ephone-dn  9
label 41210
name User One
preference 4
no huntstop
ephone-dn  10
label 41210
name User One
preference 5
no huntstop
my problem is how from the same phone I can access the mailbox for 41210? how can reception know that there is a message under 41210?
can you post an example please?
thank you!!
phone with 2 lines
A phone's MWI lamp is lit only when there is a message waiting for the phone's primary line (line 1). For phone lines other than the line that is designated to receive MWI, an envelope icon is displayed next to them when there is a message waiting."
You can use 'mwi-line ' under the ephone to over-ride which line button the lamp 'watches,' but the lamp has traditionally only followed a single extension. To designate a line other than the primary line of an ephone to be associated with the ephone's message waiting indicator (MWI) lamp, use the mwi-line command in ephone configuration mode. To return to the default, use the no form of this command.
mwi-line line-number
no mwi-line
**line-number - Line number to be associated with the MWI lamp.
Manish
phone with 2 lines
Hi.
+5 to Manish for his usual helpful suggestions, than to access VM from line 2 to 6 , just press one of those line buttons, followed by envelop key on the phone.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
phone with 2 lines
Thanks for completing the set of instructions Carlo [+]
Manish
132
