Phones are not registering to CME router
Good day all,
I have a CME router. DHCP is configured on a 4500 core switch. The phones are picking IP address on the voice Vlan. The tftp is also ok. But the  challenge is that the phones are not registering to the CME. Find attached my configuration
  • IP Telephony
2 ACCEPTED SOLUTIONS
Can you please no shut the
Can you please no shut the telephony-service and check whether phones are getting register or not ? if not take debug which i have mention in my first thread
Br,
Nadeem
Br, Nadeem Please rate all useful post.
CME#conf tEnter configuration
CME#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
CME(config)#telep
CME(config)#telephony-service
CME(config-telephony)#no shut
Hello
Hello
Why you telephony service is in Shutdown state? Do no shut under telephony and run this debug and check are phones getting registered or not? also does your phone getting TFTP ip address? what does it show on the phone ? Is it in registering state?
debug ephone detail
telephony-service
 no auto-reg-ephone
 max-ephones 350
 max-dn 4
 ip source-address 10.1.0.1 port 2000
 max-redirect 5
 auto assign 4 to 6
 auto assign 1 to 5
 cnf-file location flash:
 load 7942 SCCP42.9-3-1SR4-1S.loads
 load 7975 SCCP75.9-3-1SR4-1S.loads
 load 6921 BOOT69xx.0-0-0-14.zz.sgn
 date-format dd-mm-yy
 max-conferences 8 gain -6
 web admin system name Customer secret 5 $1$FMtR$sT3uVeM.oBYRlaOQSqvXj/
 transfer-system full-consult
 create cnf-files version-stamp 7960 Jul 07 2014 10:33:15
 shutdown
Yes my phone is getting the
Yes my phone is getting the tftp server address. It is just showing registering for a very very long time
Br,
Nadeem
In addition to that, collect
In addition to that, collect 'debug tftp events' and 'debug tftp errors'
Thanks for your support. Pls
Thanks for your support. Pls how do I perform the no shut command for the telephony service?
CME#conf t
CME(config)#telep
Thanks all. This worked
Thanks all. This worked perfectly well. I did a no shut on the telephony service.
I am grateful
374
