Phones at the same partition
Hi, i have a trouble, at CUCM has two phones in the same partition with the same CSS, but i just only can call to one phone, i have reset the line, the phone, uninstall the phone and reinstalled it again. anyone can help me please.
Re: Phones at the same partition
That's really not clear.
Is this a shared line?
Are the 2 DNs the same but on different partitions?
CUCM version?
If they're something like
1111 PT_1
1111 PT_2
It's expected you can only call one of them, CUCM will call the 1st one in the CSS when it comes to the order of the partitions
If not, provide more details.
java
if this helps, please rate
java
www.cisco.com/go/pdi
thanks for your answer, i'll give more details...
i have two phones, with diferent lines
22100 - Phone 1
22200 - Phone 2
This lines, are at the same partition and the same Calling Search Space, but when i call to 22100 the call completes, but when i call to 22200 i returns a sound of busy... What can i do?
Thanks for your help and answers...
Try deleting the DN and recreating it, make sure there is nothing else you could match in the unassigned DNs
java
java
126
