Phones - Extension Mobility
I'm running CM 6.1 and using extension mobility, it's all working fine except one small problem, when I search for the phone by directory number of the EM user I can't find it, all phones are showing up as the auto-reg number and not the DN that is logged into the phone.
Has anyone seen this before?
Tks
Paul
1 ACCEPTED SOLUTION
Re: Phones - Extension Mobility
on the related links option from device -> phone select the EM option to view currently logged devices
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
Thank you very much
119
