07-17-2008 12:06 PM - edited 03-15-2019 12:02 PM
I installed like 150phone on a cisco call manager 6.1. i noticed that the phones reset often on their own.
Can someone tell me what could be responsible and how i can solve this.
Thanks in advance
07-17-2008 07:17 PM
Do you suspect that they are loosing connection with the callmanager? Do you think that they loose power all together, or just reset? Do they all reset at the same time, or sporatically? Are the ones that reset common to a switch in particular (POE switch)? Is it only a particular subnet of phones? Is it one type of phone (7941s only), or all phones and types? Does it happen during a particular time of day, or anytime? Etc., etc.
Just some thought provoking questions, to help narrow down what is actually going on.
07-17-2008 10:43 PM
Can you also post what you see on Phone Setting->status-> Network statistics and status when the Phone in question is restarting .
07-18-2008 03:53 AM
The phones reset sporadically
On the Network Status it shows
Rx Frame:
Tx Frame:
Rx Frame:
Elapsed Time:
Reset-Restart
Port1 100 Full
Port2 100 Full
DHCP disabled
Hope to hear from you
07-19-2008 11:38 AM
Anyone with an answer shld pls respond
07-19-2008 10:07 PM
hey
as john mentioned, there are many things to consider with this. im responding because im having phones at one of my branches resetting once everyday for the past month. im still troubleshooting, however, its not actually an issue with phones per say. i have narrowed this down to my input queue being overwhelemed and that drops all data for one second. Still in the process of finding out what is causing it
have you taken a look to see if any errors exist on the swtiches/routers, whats the staus messages on the phones, do you have any thing monitoring the network?
whats the background on the issue. were these phones working for a while and it just happened or is it happening since install? Are all phones affected,was an upgrade done, is there any slowness on the network etc etc....
04-20-2009 12:35 PM
Any luck resolving this? We have a similar issue.
