Phones restarting
Hello.
I have a strange issue with ucm 8.6.
Cisco phones (sip firmware) restarting in a few seconds after call established.
It happens during any type of calls, onnet and offnet. I have attached sdl trace.
Any ideas what can be wrong?
  • IP Telephony
2 ACCEPTED SOLUTIONS
Phones restarting
what is the phone type and what is the firmware load on the phone?
Your cucm is 8.6.x?
Voice CCIE #37771
Phones restarting
Have a look at the following link:
https://tools.cisco.com/bugsearch/bug/CSCtq94673
Voice CCIE #37771
Phones restarting
Your cucm is 8.6.x?
Voice CCIE #37771
Phones restarting
Phone types are: 7906, 7911, 7942, 6921.
Firmwares are: SIP11.9-2-1S, SIP42.9-2-1S, SIP69xx.9-2-1-0
cucm version is: 8.6.2.10000-14
Phones restarting
Voice CCIE #37771
Phones restarting
We have updated our cucm to version 8.6.2.20000, but problem still remains.
Any other ideas?
Phones restarting
Hi Dmitry,
Can you check the following:
Does the phone reset or does it restart completely?
Any errors on the switchport?
Is the issue specific to a site or a specific model of phones?
Do we have the detailed callmanager traces for a call that experienced the issue?
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Manish
Re: Phones restarting
Hello Manish,
The phone resets to Cisco logo, configure ip and re-register on the server.
No errors on switchport.
We have single node on vmware esxi. The issue observed on any phone (7906, 7942 and others).
I have attached trace logs. Last call was made around 10:22, phone name SEP002155D45D52
Hi Dmitry,
Can you share the calling , called party detail and also the approximate duration after which the phone reset during the active call? This will save me some time in looking through the trace.
Manish
Calling number is 2400. Called number is 989218945054.
mac of the calling phone 002155D45D52
Call started at: 10:22:05.262 27.10.2014
Ended at: 10:23:08.144 27.10.2014
Phone reseted after a few seconds. 5-7 seconds.
Hi Dmitry,
I see the phone unregistering with Reason code 13
10:23:05.479 |EndPointUnregistered - An endpoint has unregistered Device name:SEP002155D45D52 Device IP address:5.200.43.77 Protocol:SIP Device type:369 Device description:test_cucm Reason Code:13 IPAddressAttributes:0 LastSignalReceived:SIPStationDPrimaryLineTimeout CallState:2400-disconnect_request11 App ID:Cisco CallManager Cluster ID:StandAloneCluster Node ID:cucm|AlarmSEP002155D45D52^*^SEP002155D45D52
10:23:05.479 |-->RISCMAccess::DeviceUnRegister(...)|*^*^*
Reason code 13 is in general network related connectivity issues and specifically it points to TCP keepalive timeout between IP{ phone and cucm.
Manish
367
