Phones Unregistering
estadlercisco
I'm trying to resolve an issue with phones unregistering from the callmanager over a VPN connection. Almost daily the phones register to the local gateway and the tunnel does not go down. I attached the log of the local SRST gateway to which the phones are registering.
Tommer Catlin
The phone is timing out when trying to find the callmanager. SRST is depended upon a trigger on the phone. If the phone does not get a response to the callmanager specified in it's TFTP configuration, it will fall to the SRST specified and register. Somewhere you have a tunnel dropping or too much latency between the phone and the cucm cluster. There may be a timeout you can increase in the service parameters, but I do not have it in front of me. Possibly someone can add some more comments
