PickUP Button 6911
I would like to enable the "Call Pickup" function in a 6911 phone. And in the phone button template of the 6911 SCCP, I see 10 buttons.
The button number 1 is the Line and the other buttons are Speed Dials. What is the number of button that allows pickup calls??
Thanks!
Green
PickUP Button 6911
Firstly check the settings on the phone and find out what SOFTKEY TEMPLATE is being used.
Then you need to look under the Device --> Device Settings --> Softkey Template
Select the the Template that your phone is using.Lets say its Standard User
In the top right hit the GO button against Softkey template configuration
Change the centre drop down to "Off Hook"
You shoulod see that the Button for Pick Up  is already selected.
I have also checked this for Standard Feature template too.
Remember to use the Pickup function the phone has to be OFF HOOK
Alex
Regards, Alex. Please rate useful posts.
PickUP Button 6911
Hi and thanks Alex,
The configuration of the 6911 is:
Phone parameters:
Phone Button Template: Standard 6911 SCCP
Softkey Template: Standard User
Layout Stadard 6911 SCCP
1. Line (enable)
2. Speed Dial
3. Speed Dial
4. ....
10. Speed Dial
Layout Standard User Template:
Call State to configure: Off Hook
In the Selected Softkeys: Redial, End Call, Forward All, Pick Up, Group Pick UP Meet Me.
Whit the above configuration, I performed test of pickup calls within the same Pickup Group, as follows:
I hear the characteristic sound of the pickup group feature, then I pick up the handset of the telephone (off hook)
and press the button, but I am unable to capture the call.
Hall of Fame Super Red
PickUP Button 6911
Hi Matthew,
I just wanted to add a link to this thread in addition to the great tips from Alex (+5-A)
We don't use any 6911's so I can't test this for you, but I thought this was interesting
and somewhat related to your query
https://supportforums.cisco.com/message/3224216#3224216
Cheers!
Rob
Green
PickUP Button 6911
Hi Rob and Mathew,
I did eventually dind this a 1/2 hour ago.
I have tried to configure on my lab 8.6.
It is very wieldy.
Select the phone
Modyfy the set up
Move call pickup up to say position 2
Save & reset.
Calls comes in
lift handset
press the
button, followed by 2
Nothing is easy any more.
Alex
Re: PickUP Button 6911
The correct configuration is as follows:
1.-  Device >> Device Setting >> Phone Button Template
1.1  Add a new Button Template Name:
2. Apply the new Phone button template to the 6911 phone
3. Lifting the handset, press the key and then press the 1 key. ( button 2 -1 = 1)
PickUP Button 6911
When I attempt I get this message, can you help? It reads, "There are no associated devices to restart"
PickUP Button 6911
Hi Zimran,
I believe this message is just indicating that there are not any Devices currently using
that Button Template, thus, no Devices to reset.
You might be creating a new Button template which would then have to
be assigned to the specified phones
Cheers!
Rob
"Celebration it's around us, every nations, all around us.
Singin' forever young, singin' songs underneath that sun" - K'naan
PickUP Button 6911
Here's how I did it:
ephone-template 1
     feature-button 1 Gpickup
ephone-dn 1
     pickup-group 1
ephone 1
     type 6911
     ephone-template 1
telephony-service
     no cr cnf
     cr cnf
ephone 1
     reset
then, to pickup, take the phone off hook, press the feature button (
https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/2-3616712-87179/38-26/buttom.png) and press "1" - and now the call is picked up
1203
