Pickup Groups
How do I find the list of extensions in a pickup group.
Using callmanager - System version: 7.1.2.20000-2
Hall of Fame Super Silver
Pickup Groups
Did you try using dependency records?
Chris
Pickup Groups
by default they are not enable,
you can enable the dependencies record from the enterprise parameter.
thanks,
Vipul Jindal
Re: Pickup Groups
Go to Device> Phone
Find Phone where Call Pickup Group contain and click Find
It will show device name of the phones, may be you can put the directory number in description
Pickup Groups
Or you can use 2 filters
Find Phone where Call Pickup Group contain Click +
                           Directory Number begin with            Click Find
this way it will list the device name, extension that in the pickup group you key in but you will not see pickup group name
Pickup Groups
Thankyou - solved
thanks so much for your help
197
