Pilot point CM6.0 need urgent help
I have 3 pilot points 2 of them were registered, because the last didn't register i restarted the CTI manager service and the CM service after i tried everything, but tbe pilot points are still not registered and stand on unknown
1 REPLY
Re: Pilot point CM6.0 need urgent help
make sure the pilot is associated to the right user, try to de-associate/re-associate it. then reset the PP
java
if this helps, please rate
java
www.cisco.com/go/pdi
97
