Pin authentication for calling IDD - CME 4.1
Is there a way to give authentication for International calls using PIN for the users.
Is there a script for it? could you please provide to me?
FYI: im using CME 4.1
manoj
1 REPLY
Hall of Fame Super Gold
Re: Pin authentication for calling IDD - CME 4.1
There are some scripts for this already in the box. Do "show call application voice summary" and "show call application voice" to see them all in detail.
You can also do without a script, just configure the DP with PIN as destination-pattern to be prepended to the number to dial.
157
