Pin for Personal Directory
Hii,
There is any option to give for 2.800 Users one  pin nr. an they can change after from Webb access interface.
1 ACCEPTED SOLUTION
HI,I find a fix up for this
HI,
I find a fix up for this.If I go to Bulk Administration/ Users/Reset Password/PIN/Query and find the user.id and Enabled User Must Change at Next Login and write a PIN and Run Immediately. After the Job is done every user have to go Web access and change the PIN and then can go to Personal Directory on the Phone and type the new PIN.
I am guessing you are using
I am guessing you are using CUCM and adding these users as End Users on the CUCM. Is this CUCM?
In that case, you can use the Default Credential Policy to set the PINs for all the end users to a certain value after which they can change it to their required value. It's under User Management -> Credential Policy Default.
Note: You need to create a new entry in the User Management -> Credential Policy first. Then you will be able to see the same entry in the Credential Policy Default.
Hi Sreekanth I think this is
do you have LDAP integration ?. For sure you have CUCM.
please rate all useful information
hikindly find the below
hi
kindly find the below link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/bccm-712-cm/b08user.html#wpxref95190
thanks
hi, I have LDAP configure on
hi,
I have LDAP configure on the CUCM, you say if a want to enable for all user I have to disable the LDAP and after I finis to config End User to enable LDAP?
Hino , do not disable LDAP.
i just wonder if you have LDAP integration or no .Do not disable LDAP. kindly follow :-
 User Management -> Credential Policy >choose User Must Change at Next Login and does not expire. Use default credential policy to define pin to all users.just follow the link which i shared above
thanks
After I put a default pin on
After I put a default pin on User Management / Default Credential Policy/ End User/PIN with my user uid it's working, after I put another user uid I receive the login unsuccessful  with the mesage PD Error Message.
Hi1- Can you enable "does not
1- Can you enable "does not expire"?.
2- Try more than userid .
Hii, The problem is now if i
Hii,
The problem is now if i change the PIN from Credential Policy/Default Credential Policy  not working anymore, it's like it keeps the old pin, when I go to web User Web page and I want to change the PIN it's working to change only if I put the old pin nr. Maybe I have to change  some option in other part of CUCM?
I can enabled the User cannot change/User Must change at next Login/Does Not Expire
Hi 1- no , you have only use
1- no , you have only use user cannot change or user must change on next login .
2- yes , the user should login for the pin which already configured by you as default , then he can change .
Hi, I put in attachment the
I put in attachment the setting from My CUCM/EndUser/Web access.
1.Now I change the pin from DCF to 12345678 and I left the User Must Change at Next Login ENABLED
2. I go to Web access and i type the curent pin ( 12345678 ) and write a new personal pin ( 123) but ai receive the error Current PIN incorrect .
Pls check the attachment
Th a lot for help
Hello can we do one test ,
Hello
can we do one test , please ?. Just check only for do not expire and uncheck other choices , and test for more than useid , if it work let me know .
Hi,I think the problem is
I think the problem is from LDAP, when I change the pin form End User Configuration and I give the PIN to user it's working fine. If i disable the LDAP I will lose all the user uid from the END USER  or just not able to synchronize  other  user from AD. If I don't lose the user I can disable LDAP and give a general PIN and after the user receive the PIN  just Enable LDAP again.
It's possible???
Hino , LDAP will overwrite
Yes , you can disable LDAP then enable it and resynch. Can you please go to CUCM-user management- credential policy default and type a new password , then select Do not expire , and select also user change at next login. Do not change anything from edit credentials for userid .
Hi1- do not touch edit
1- do not touch edit credentials for end user.id as you did for uidl7366.
2-Please check do not expire.
thanks
Hey, I add in AD a user and
Hey,
I add in AD a user and log in to web access with the user.id and it works, after I go to User setting to change the default pin I receive the message the Default PIN is wrong:(
I do not understand  what I am doing wrong :(((((
HiAre you sure that you check
Are you sure that you check change in next login , please check.
I test only  with Does Not
Now I left only User Must Change at Next Login ENABLED and I change the pin to 1234. I will wait 5 minutes and i will log in to web access to see if it's work.
Th
HI,
+5 for you , i know this
+5 for you , i know this solution but i think it only used when we used BAT tool will be ok with LDAP integration but i was going to advise you about. Anyway i am so happy that you fix your problem.
Thanks a lot for help :)
Thank so much for your
Thank so much for your patience and have a nice day. many thanks that you share your final solution which hit the issue.
thanks
Hi Just keep this url as
Just keep this url as reference
https://supportforums.cisco.com/discussion/11516276/extension-mobility-disable-change-pin
thanks
please rate all useful infromation
HelloJust after you did
Hello
Just after you did change on credential policy . Just do one thing to make sure , just add a new user on AD and do resync , and check if he can able to login again or not.If the policy applied and this will be 100% , so we will disable LDAP and we apply it again ,if the test failed so keep your LDAP running.
428
