Community Member
PIN length
in all CallManagers I take care of is PIN length selectable from 5 up to 20 numerals. But in one of them (only the one which is connected to Microsoft AD2003) is PIN selectable only from 5 to 9 numerals. Not only in CallManager User configuration page. Also in ccmuser web page is written "Your PIN must be from 5 to 9 digits".
I don't know why but the customer requested 12 numerals :-(((
Any idea what (and where) to change ?
Thanks for any suggestion.
Installed CCM 4.2(3) without any SR
Jiri
Green
Re: PIN length
Hi Jiri,
AD Directory
Open AdsiEdit on your DC and go through the following path.
Your Domain >> DC = Domain, DC = com >> OU = Cisco >> OU = CCN >>
OU = systemProfile >> CN = System
Profile.
In the properties look for " ciscoCCNatPINLength ". Modify this to the value you required
Gonzalo
Community Member
Re: PIN length
Hi Gonzalo,
I checked this value - now is set to "5". But I think that this value is related to "Minimum PIN Length" not to maximum. Is this correct? My problem is how to set maximum PIN length.
Jiri
108
