PIN Setting
Is there a way for a IP Phone user to change the PIN setting from the Phone itself, instead of doing the same from user options webpage...
I'm using CUCM 6.1
any inputs??
Hall of Fame Super Silver
Re: PIN Setting
Sorry, no such feature exists natively.
Chris
Re: PIN Setting
Dear sir,
How can i assign pins to cisco ip phone 7911. I m using CME. Can u plz tell how to configure it. Like i want users to login into to ip phone before dialing internationl numbers.
Will be thankful for your reply.
Malik
Hall of Fame Super Gold
Re: PIN Setting
Re: PIN Setting
Thanks for you support.
Best wishes,
Malik
429
