Ping problem with avaya VoIP phones
whenever i try to ping a avaya voip phone from a cisco device, i do not get a continuous response.
MS_VOICE_MEX_R01#ping 172.31.2.52 repeat 100
Sending 100, 100-byte ICMP Echos to 172.31.2.52, timeout is 2 seconds:
Success rate is 67 percent (67/100), round-trip min/avg/max = 1/1/4 ms
MS_VOICE_MEX_R01#
But when i try to ping the same from a desktop i do get a continuous response.
Can anybody tell me the reason for this
Narayan
1 ACCEPTED SOLUTION
Community Member
Re: Ping problem with avaya VoIP phones
Avaya IP Telephones implement an ICMP rate limiter. The Microsoft ping.exe command sends pings 1/second avoiding the rate limit. A Cisco 3825 sends pings at about 1/ms easily tiggering the rate limit.
Bronze
Its funny while back my friend had the same issue, i asked him if he ever found a reason so he sent me this link:
http://www.avayausers.com/showthread.php?threadid=1906
Not sure wether its true or not but thought it was interesting. Maybe a Avaya rep has a better answer.
Milan,
I don't think this is to prevent the DOS attack cos i am always able to ping the phone from any desktop continuously.
It only shows this absurd behaviour when i try to ping from a network device like a router/switch
Narayan
Community Member
Thanks for the info..
Is this documented somewhere though
Narayan
Community Member
3494
