Pix 515E VPN Can't connect Hyperterminal
I've setup the VPN for tech access to our network.
Everything works but the network admins are having problems trying to access our routers via Hyperterminal when logged in to the Pix VPN.
I could believe it's a port 23 issue.
Is there any way to open port 23 to be able to use hypertermianl when VPN in and make it at the same time secure enough?
Please let me know if you know the configuration.
Thanks in advance.
Zeek
  • IP Telephony
1 REPLY
Re: Pix 515E VPN Can't connect Hyperterminal
We figured it out.
We nedded to allow telnet access to every router from the VPN ip tunnel.
204
