Planning DIAL PLAN for cisco communiations manger express (CCME)
Please i am implementing IPT express solution. I am searching for a detailed document for planing CCME dial plan. Would be grateful for any help asap.
1 REPLY
Re: Planning DIAL PLAN for cisco communiations manger express (C
i guess you mean NANP, there is no specific doc but there is plenty of info on the web
North American Numbering Plan
http://en.wikipedia.org/wiki/NANP
simply create usual patterns, 7, 10, 11 digit dialing, international calls, 911, etc
java
if this helps, please rate
java
www.cisco.com/go/pdi
125
