PLAR configuration with 3911 phone
I was wondering if it is possible to configure a PLAR line with a SIP phone 3911 and a CUCM 6.1. I think I cannot use the dial rules because they are intended to be used only with 79XX phones, am I wrong?
I tried to use the SIP dial rules, however it didn't work.
  • IP Telephony
Anonymous
N/A
Re: PLAR configuration with 3911 phone
Cisco Unified SIP Phone 3911 does not support KPML (Key Press Markup Language) which allows for the digits to be sent to Cisco Unified Communications Manager digit by digit. Cisco Unified Communications Manager defaults to the use (KPML) when SIP dial rules are not configured. To ensure successful call completion, you must use the 7940_7960_OTHER dial rules pattern to configure a SIP phone dial plan and to associate the plan with the Cisco Unified SIP Phone 3911.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/3911/6_0/english/administration/guide/3911AG.html
In order for PLAR to work the phone has to be able to support Barge. 3911 doesn't support this feature therefore PLAR isn-t support on it. As an alternative you can use other models like the 7905 or the 7912.
HTH,
pablogon
Dear pablo,
So there is no chance to do the PLAR with 3911, if i configure SIP DIal rule.....with  7940_7960 _OTHER....?
292
