PLAR/ Ringdown not working in version 8.6.2
Hey Guys,
Have any of you done any ringdowns or PLAR's in 8.6.2?
I'm at a customer and they have a bunch of them for elevator phones and intercoms that are not working. I created a brand new one and it does not work as well.
I configured a new Partition. Call it PLAR-pT
i create a new CSS. called it PLAR-CSS
make an extension on a phone 5000 in the Plar-PT with auto answer turned on
make a blank translation pattern in the Plar-PT that dials 5000
on the phone i want to use the ringdown i give it the PLAR CSS
i press the line like i used to and it gives me dial tone instead of using the blank translation and calling extension 5000
any ideas?
Ken Waldecker
Senior Solutions Engineer
NWN Corporation
336.217.1383 office l 336.908.2187 mobile
7025 Albert Pick Rd - Suite 302, Greensboro NC 27409
www.NWNIT.com
1 ACCEPTED SOLUTION
Ken,
Does the Translation Pattern have the Urgent Priorty checked?
Yosh
HTH Regards, Yosh
Ken,
Yosh
HTH Regards, Yosh
it was the urgent priority check.  for some reason it wasn't there after the upgrade.
that fixed it!
thanks!
Hall of Fame Super Silver
There should be nothing in the PLAR-pT except for the blank TP, you said you assigned it to the phone DN as well, this basically makes the TP unusable as DNs are always preferred even with urgent priority TP.
You need to assign other parition to this DN that is reachable from the CSS on the TP, the PLAR device needs to have the PLAR CSS assigned to it.
Chris
410
