PLAR with delay of 6 seconds on FXS ports
Hi there
Is this possible???
If I lift the analog phones connected to the FXS port on the VG224, I should be able to dail out to any number however if I jlift the phone and keep it off-hook for 6 seconds without dialing any number, then it should dial out to a particular number.
is it possible??
Re: PLAR with delay of 6 seconds on FXS ports
Please provide details of what system you are using (CallManager or CallManager Express), the version number and the protocol running on the gateway.
Call manager 7.0
VG224 on SCCP.. i want is if i lift the handset on the analog phone i can dial the number but if i do not dial any number for 6 seconds then it should auto dial to the operator
anybody????????????
327
