Platform configuration disk for MCS-7825-I3
I'm trying to install a Unity VoiceMail in our newly received hardware (MCS-7825-I3-CCE1/CCX1/ECS1/IPC1/RC1/S31) but the installation is failing to install because I don't have the right PCD (Platform configuration disk)
The message I'm getting is:
WARNING!
This Configuration CD is not
Supported on this server model
Press <ESC> to Exit
Can you please advice how to download or order this CD?
Thank you
1 REPLY
Re: Platform configuration disk for MCS-7825-I3
Hi!
The only way to get this SW is placing a CD request and you need to follow the next procedure:
Go to the Product Upgrade Tool (PUT)
http://tools.cisco.com/gct/Upgrade/jsp/index.jsp
or
www.cisco.com/upgrade
(registered customers only). You'll be required to enter your Cisco Software Application Support Plus Upgrades (SASU) contract number and request the CD/CD set.
If you have any problems finding the part numbers that you need or with the order placing please send an email to mp-upgrades@cisco.com
Just send them an email requesting the SW CDs that you need, adding your contract number and the shipping address.
If you have a CD mis-shipment problem, then the Customer Service department should be involved. They can be contacted at
cs-support-us@cisco.com.
For more information you can call Customer Service at 1-800-553-6387
Finally I'm sending you all the detailed info about the procedures on CDs requests, for future needs:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a00802262ed.shtml
NOTE: Cisco TAC does not provide installation media.
Hope this helps :)
Regards, Tere. If you find this post helpful, please rate! :)
122
