Platform Mismatch for Meeting place express 2.0.2 .
k_sinjish
Hi ,
We have installed Meeing place express version 2.0.2 in a MCS 7845-I2 - CCE1 .
1. The installation has happend very first time in a fine way .
2. After that we observed the system was keep on restarting and giving the below given error message .
" An error occured during the file system check .
Preparing you to a shell :The system will reboot "
3. Then we tried to do the fresh installation , we are getting an error message as the platform is an invalied one .
So please suggest us how to procced with this and is there any BIOS reset needed for the same .
Regards ,
Sinjish.K
jbayuka
Level 5
Level 5
Can you confirm that the server does not have raid enabled in the bios?
Also what is the version numbers listed on the CD?
