Playing MoH from Remote router
How can i move the moh file to a remote router in call manager 5.1?
Any help please.
Re: Playing MoH from Remote router
Take a look at the following link.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802d1c31.html
Hope this helps. If so, please rate the post.
Brandon
Thank You for this pdf it was so useful for me but i have one more question.
Is there anyway to import the codec moh files from the callmanager 5.x?
In 4.x it was easy we can find them in this link C:\ProgramFiles\Cisco\MOH\moh.ulaw.wav
Can we do the anything to do that in call manager 5.x
Not that I'm aware of. If it's the default MOH files, they should be on your installation disks. If it's custom MOH, you should have these files somewhere other than on the server.
Brandon
i tried the steps on the pdf file but when the hold button pressed no sound appear. Just silence.
what is the problem?
Please advice.
174
