Please explain transforamtions and transalations
I am new IPT and struggling to grasp the concept of calling/called number translations and transformations.
Can anyone please explain me the above with a simple example.
Translations affect call routing.
Transformations affect display.
GTG
Please rate all helpful posts.
Thanks for your response.
So u mean transforamtions are used to change the dispay of the number lets for outbound/inboud calls..?
Can explain with a example please.
Say you have two offices: London and Paris.
Extensions in London are numbered 2xxx
Extensions in Paris are numbered 3xxx
There is no direct link between the sites, other than using the PSTN.
On London, you would use a translation pattern to translate 3xxx numbers into the full internation number, and in Paris you would do the same for the 2xxx numbers.
Then, on the London switch, you would use a transformation pattern on the calling number, to transform the full internation number of Paris into a 3xxx number.
So you're hiding, from your users, the real PSTN numbers of the other office. Your users only have to deal with the four digit extension numbers.
GTG
100
