Please few steps on how to config a CCM 6.1.2
Hi guys,
I will need few steeps on how to setup a call manager 6.1.2 with a 2811 as a gateway. I'm very new with Call Manager and I have to finish this project till Friday. Please help me,
So I have:
1 - 2811 with 1MFT T1/E1 and 8 FXO
1 - 7816 server running Call Manager 6.1.2
What I have done:
- Installed call manager and uploaded the license files (500 seats, 200 units)
Re: Please few steps on how to config a CCM 6.1.2
Maintain and Operate Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
download :
Cisco Unified Communications Manager Administration Guide, Release 6.1(1)
look at the GW config part, you do not mention which protocol you want to use so look at the appropriate doc
Configuration Examples and TechNotes
http://www.cisco.com/en/US/partner/tech/tk1077/tech_configuration_examples_list.html
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks javalenc for the links.
I still am little bit confused with all the info that I have to read.
I will use MGCP as protocol for gateway.
But I don't know how to config the gateway. If someone can put a running config I will appreciate a lot.
I don't know if I must put the phone firmwares on the gateway CF, or what exactly I have to do.
I have some experience with Call Manager Express but I don't know what from that experiense to use.
guess you only looked at one link since in here:
there are a LOT of examples:
# Configure MGCP Gateway and FXO/FXS Ports on a Cisco CallManager Server
11/Jan/2007
# Configuring Cisco CallManager with IOS MGCP Gateways (Analog FXO, FXS Ports)
11/Jan/2007
# Configuring SRS Telephony and MGCP Fallback
12/Feb/2008
# Configuring the Cisco IOS MGCP Gateway
01/Nov/2006
# Hookflash Transfer in MGCP
02/Feb/2006
# How to Configure MGCP with Digital PRI and Cisco CallManager
did you checked any of those?????
javalenc
java
417
