Please help with a very basic question
My company has tasked me with becoming a CCNP Voice so that I can take over the managment and maintenace of our Cisco Voice enviornment.  I just have my CCNA (in fact just got it on Saturday).  They're already starting to get me involved with the voice stuff though prior to me taking voice classes.  Without sounding foolish I was hoping someone could tell me what each of these devices is:
UCCX
Unity
UCMPU
UCMSUB
My understanding is that UCCX essentially keeps all the contact info.  Unity holds the voicemail.  The second two provide routing info.  However, I dont know where "Call Manager" lives.  Can someone give me the 60 second run down?
John
Everyone's tags (2)
Hall of Fame Super Silver
UCCX - Contact Center application, call rouiting for agents, ACD
Unity - Voicemail
UCMPU - CallManager Publisher IP-PBX, master CallManager database
UCMSUB - CallManager Subscriber IP-PBX (redundant server, primary call processor)
CallManager is central point and all others integrate to it.
Check out CUCM SRND for more details.
HTH,
Chris
Excellent, thank you.  So the third and fourth boxes make up Call Manager.  The first two add on to its capabilities.  Does that sound accurate?
Correct.
Hi John,
UCCX is a Contact Center application, usually used in call centers four agents to take customers calls and outbound campaigns.
Unity is a VM application server and you can use either Unity enterprise or Unity Connection.
UCMPUB and UCMSUB: This means that there is a 2 node CUCM/Callmanager cluster in your company. A cluster always has a single CUCM Publisher which is the one that handles the Database (where all the phones, gateways, DNs, Route Patterns, Trunks, etc are) and this PUB pushes DB info to the SUBs (subscribers). Usually the SUBs are the call processing servers (handle calls) and the PUB can be used as TFTP (to push MoH, firmware, ringtones, etc to the phones), but it can also be a call processing agent (that depends on the CCM Group configuration)
I will recommend you to go through the application datasheets firts and then the Admin Guides and SRNDs/design guides for more deep information.
If you have any question feel free to ask.
Tere.
If you find this post helpful, please rate! :
Regards, Tere. If you find this post helpful, please rate! :)
Thank you both for your help.  This gives me good information to start with.
I start my voice training next month so I hope I can answer that question on my own afterwards
If they expect you to manage and configure UCCX then they're missing something really important, which is that the CCNP Voice does not cover UCCX. You would need separate training if what they got for you is just based on the CCNP Voice exams.
My 2 cents
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Do you know which class or classes I would need to learn UCCX?  Do you know of a reputable company offering that training?  Ideally I'd like to stay near where I live (souther california), but travelling isnt out of the realm of the possability.
Hi John,
I would strongly recommend Global Knowledge or Firefly. You can look for learning partners here:
http://tools.cisco.com/WWChannels/LOCATR/openBasicSearch.do
I will also recommend that if your company is a registered Cisco Partner, you can navigate this Partner Central website which has a learning and training section:
http://www.cisco.com/web/learning/le27/learning_learning_partner_connection_home.html#4
Tere.
342
