Please help with the specks
Hi guys!
Please help come up with a viable spec for a cisco 2801 router that will connect to an ISDN PRI provider. We would then like to convert it to SIP so as to pass the traffic to astericks.
What licences and modules should be included in the specifications?
fmo
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
You need IOS Voice image, VWIC interface, and PVDM2-xx according to the number of desired channels.
Paolo hello,
If am using the CME just for the purpose of converting the E1 to SIP then forward to Astericks for dialpeers etc...do I require PVDM?
Yes.
Configuring CME is not necessary.
Thank you for the nice rating and good luck!
112
