Community Member
Please save my hair!
I am having an issue getting a 7975 to register with CME 8.8... It worked fine when the phone was directly plugged into a switch module on the router, but now that I have the phone on my desk, and the 2911 is in the DC, the phone is in a registration loop...
If I run "debug voice register events\errors" I am consistantly getting the line "Contact doesn't match any pools" & "auth absent"...
Under the command "show voice register pool X" it show's that there hasn't been any registration attempts to the configured pool:
Pool Tag 3
  Mac address is 108C.CF75.D8B5
  Type is 7975
  Number list 1 : DN 3
  Proxy Ip address is
  DTMF Relay is enabled, sip-notify
  Call Waiting is enabled
  DnD is disabled
  Video is disabled
  Camera is disabled
  Busy trigger per button value is 0
  Description is Hidehoo!
  keep-conference is enabled
  registration expires timer max is 3600 and min is 60
  username 1112 password cisco
  kpml signal is enabled
  Lpcor Type is none
  Transport type is udp
  service-control mechanism is not supported
  Registration method: per line
  Privacy feature is not configured.
  Privacy button is disabled
  conference admin: no
  conference add mode: all
  conference drop mode: never
  Reason for unregistered state:
       No registration request since last reboot/unregister
  paging-dn: config 0 [multicast]  effective 0 [multicast]
Dialpeers created:
  Active registrations  : 0
  Total SIP phones registered: 0
  Total Registration Statistics
    Registration requests  : 0
    Registration success   : 0
    Registration failed    : 0
    unRegister requests    : 0
    unRegister success     : 0
    unRegister failed      : 0
    Attempts to register
Yet I have what appears to be all the requisite commands per my internet browsings:
voice service voip
allow-connections sip to sip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
  bind control source-interface Loopback8
  bind media source-interface Loopback8
  registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address port 5060
timeouts interdigit 3
max-dn 100
max-pool 50
load 7975 SIP75.9-2-3S
authenticate register
authenticate realm all
timezone 8
tftp-path flash:
file text
create profile sync 0004336253345316
user-locale 1 US load CME-locale-en_US-English-
ntp-server mode directedbroadcast
voice register dn  3
number 1112
name Yehaa! 1112
label Yehaa! 1112
voice register pool  3
id mac 108C.CF75.D8B5
type 7975
number 1 dn 3
dtmf-relay sip-notify
voice-class codec 1
description Hidehoo!
no vad
What am I doing wrong!?... I came across the Cisco site below that references something similar to what I am experiencing, yet the 7975 doesn't have the ability (that I can see atleast) like the 7960 has to change the username\password via the settings button:
I did scp down the xml file for the phone from the router and the username\password combo are exactly the same as those define in the voice register pool 3...
Via the command "debug ccsip message" I am showing the following:
000679: Jul 12 17:39:54.371: //183/B1ED40A2806E/SIP/Msg/ccsipDisplayMsg:
u SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP;branch=z9hG4bK1c1abccc
From: <sip:1112@>;tag=108ccf75d8b5000316a4e8f8-a0ab50dc
To: <sip:1112@>;tag=BC5974-1889
Date: Thu, 12 Jul 2012 23:39:54 GMT
Call-ID: 108ccf75-d8b50002-d0eb8ea8-581803ec@
Server: Cisco-SIPGateway/IOS-15.2.3.T
WWW-Authenticate: Digest realm="all",nonce="78DAD3D10012D5BE",algorithm=MD5,qop="auth"
Content-Length: 0
I apprecate any help you can lend!
Instead of command under voice reg pool
try ans use command
username 1112 password 1112
Let me know if it works.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Community Member
Hey Ronak,
Thanks very much for taking the time to help me out! I apprecate it.
So, I finally got the phones to register with CME and the solution ended up being associated with that fact that I am running a VRF on the 2911... Arrgh... I ended up coming across a document that indicated the need to designate a VRF as a "voice" vrf using the command "voice vrf XXXX". After doing this, the phones registered great.
Thanks for your help!
Hall of Fame Super Gold
Beside the issue at hand.. Shy SIP? You loose features, and gain trouble compared to using SCCP..
