PLZ help-Back ground image in 7961 and CUCM 6
I did
1 upload the attached List.xml file to Desktop directory in TFTP
2 uploaded the attached images to desktop directory in TFTP
3 restart tftp service
But still in userpref>background shows only the default image...please help
Re: PLZ help-Back ground image in 7961 and CUCM 6
you need to upload all the files to the correct directory:
7941 / 7961
Full size image- 320 pixels (width) X 196 pixels (height).
Thumbnail image- 80 pixels (width) X 49 pixels (height).
Directory "Desktops/320x196x4"
java
if this helps, please rate
java
www.cisco.com/go/pdi
I done that.
Then do I need to restart the TFTP service?
Also
Can u help me to fix an idle screen logo?
ok, so ALL the files are now in the right directory?
if so try resetting the TFTP service and make sure the phone is looking at that TFTP server
java
java
235
CrearPor favor para crear contenido
