POE CLASS 4 for 9951 phones
Hi im roger
i already bought 3 9951 phones and a 7975 for the office but i wont the power cube 4
i read this https://supportforums.cisco.com/message/1172505#1172505 was good but i didnt find for class 4
and this http://en.wikipedia.org/wiki/Power_over_Ethernet  its more explaining
So the question is class 4 its the same for POE+?
and which small or medium switch i can get?
and if can i use the 2800 or 2900 routers with AC-IP?
thanks!!
Hall of Fame Super Gold
Re: POE CLASS 4 for 9951 phones
I the 9951 requires up to 20.0w of power.  The only switch models that can do this is the 3560E and 3750E (with the correct IOS, of course). The 2800 will not be sufficient but I'm not sure about the 2900.
Hall of Fame Super Red
Hey Roger,
Just to add a touch to the great info from my friend Leo (+5 buddy....we had our own
Canadian Country version of "setting the Coat Hanger ablaze" at New Years with 6-18
inch Sparklers hahaha!!)
This is an excellent thread about PoE for the 9951;
https://www.myciscocommunity.com/message/27875;jsessionid=2803C635EB8687EE4C7E09777FA4FD5B.node0
Hope this helps!
Rob
Thanks Rob!
Thanks rob and leo
nice thread rob
So in advance resume from the rob link
4) Power is listed as 802.3af and 802.3at support.  Are there any limitations when using 802.3af instead of 802.3at? I am guessing the USB ports may require the Class 4 PoE?
If using 802.3af power and wish to take advantage of the Cisco Unified IP Color Key Expansion Module for expansion of line/feature appearances, then power cube 4 power supply (supporting the IP Phone) is required to support the module or modules (actual number of modules is phone model dependent). Also note that 802.3af supports up to 15.4W of power to a given device and the classification of the power consumption is static and cannot be renegotiated later on. The AT specification allows power consumption up to 25W PLUS the ability to change power consumption after the initial classification.
Kirk McNeill
Collaboration Solutions Marketing
Cisco Systems
It looks like the 9900 series are class 3 POE even a catalyst express 500 can power on the phone according from cisco
roger
another important question
2. Regarding the 802.3af and 802.3at support on 9900 IP phone, does this means 9971 with camera will be able to be supported by a 802.3af switch port as well?
Yes, the 9900 Series endpoints can support the Cisco Unified Video Camera, upon its availability, with Class 3 IEEE 802.3af. If one wants to add the IP Color Key Expansion Module, that would require purchase of the Power Cube 4 for local powering of both the Phone and Key Expansion Module.
Kirk McNeill
Cisco Systems
a good news so the 9900 series its a regular poe phone and can use full features like full color, bluetooth, and video camera with poe class 3
roger
3.What about support for the 9971/51 with UC500 and CME environments?
View for UC-500 is targeting support mid-year 2010.
View for Communications Manager Express with Integrated Services Router (ISR) is roadmap item for CY 2H 2010.
kirk
this link its nice to those who want to know more about 9900 phone series
http://www.slideshare.net/georgenistor/cisco-ip-phone-update
this tool is a calc for POE in cisco switch family
http://tools.cisco.com/cpc/launch.jsp
So i already order the phones to test them to update the thread
thanks
8436
