Community Member
POE is IOS dependant or Hardware Dependent
HI,
I just wanted to know, if the Power Over Ethernet (POE) is base on the IOS or is dependent on the hardware?? i have 3550 series Cisco Switches and wanted to know if i can enable POE over them???
Kindly Help me with your suggestion.
VIP Purple
Re: POE is IOS dependant or Hardware Dependent
POE is hardware and software dependent, but any hardware with POE capabilities should be running IOS to support it.
Hope this helps. If so, please rate the post.
Brandon
Hall of Fame Super Red
Hi Michel,
The PoE functionality is primarily Hardware based. Have a look at the following list for the 3550, and note the ** for the PoE supported version;
The Cisco Catalyst 3550 Series Intelligent Ethernet Switches include the following configurations:
Catalyst 3550-24 Switch-24 10/100 ports and two Gigabit Interface Converter (GBIC)-based Gigabit Ethernet ports; 1 rack unit (RU)
**Catalyst 3550-24 PWR Switch-24 10/100 ports with integrated inline power and two GBIC-based Gigabit Ethernet ports; 1 RU
Catalyst 3550-24-DC Switch-24 10/100 ports and two GBIC-based Gigabit Ethernet ports; 1 RU; DC-powered
Catalyst 3550-24-FX Switch-24 100FX ports and two GBIC-based Gigabit Ethernet ports; 1 RU
Catalyst 3550-48 Switch-48 10/100 ports and two GBIC-based Gigabit Ethernet ports; 1 RU
Catalyst 3550-12G Switch-10 GBIC-based Gigabit Ethernet ports and two 10/100/1000BASE-T ports; 1.5 RU
Catalyst 3550-12T Switch-10 10/100/1000BASE-T ports and two GBIC-based Gigabit Ethernet ports; 1.5 RU
From this doc;
http://www.cisco.com/en/US/products/hw/switches/ps646/products_data_sheet09186a00800913d7.html
Hope this helps!
Rob
EDIT: Brandon, you are far too quick for this poor typist :)
Community Member
Hey Thanks Guys...this was really helpfull
343
