Community Member
POE Requirements
I am very close to the limit on my UPS. The documentation for 7945 and 65 phones states that they will draw a maximum of 12 watts. Is there any info for when this occurs? does an idle phone draw the full 12 watts? Is it safe to figure actual draw as total watts/input voltage (110/220) to get the current (Amps) draw for a given configuration?
Hall of Fame Super Gold
Re: POE Requirements
Hi, the switch will tell you the power supplied to phones. However that doesn't include what the switch uses "for itself".
So the only solution is either design the power system to support the maximum stated draw, or use a clamp ammeter to measure the actual one.
Community Member
Thank you. The rub is that I do not currently have any phones or POE blades. I am trying to figure out if my UPS will handle a UCM installation or not. Can anyone provide a sh: power for 7945 and 7965 phones? They will connect to a 4506 w/WS-X4548-GB-RJ45V bldes and to a 6509 w/WS-X6548-GE-RJ45AF blades.
Community Member
have you gone thru this doc?
The Amount of Power Required
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_white_paper09186a008026641c.shtml#wp43630
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
I had not, this is perfect. Do you know if there are figures out for the 7945 and 65 phones re: power used in a non-ringing state?
Hall of Fame Super Red
Hi Larry,
Just to add a note;
Power
Q. Do the Cisco Unified IP Phone 7965G and 7945G models support Cisco inline power?
A. No. The phones support only IEEE 802.3af PoE (Class 3).
Q. As Class 3 IEEE devices, do these phones require a continuous draw of 15.4 watts (W) (standard Class 3 allocation)?
A. No. When Cisco Unified IP phones are connected to common switches such as the Cisco Catalyst® 3560 Series Switches or Cisco Catalyst 3570 Switches, the switch can automatically detect the phone type and provide the exact amount of power that the phone needs. The use of Cisco Discovery Protocol provides this greater granularity to the power classification, allowing for more accurate reporting of power consumption, and a higher density of phones on the switch. The Cisco Unified IP Phone 7965G and 7945G models will draw a maximum of 12W from a switch; this places them beyond the limits of Class 2, but below the default 15.4W value of Class 3.
Q. Is there a recommended powering option for these phones?
A. No. Powering decisions depend on the customer's environment. The IEEE 802.3af inline power method can be used; alternatively, either the standard Cisco Unified IP Phone external power adapter or the Cisco Unified IP Phone Power Injector can be used for local power.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps8537/prod_qas0900aecd80699c2b.html
Hope this helps!
Rob
i just looked at all the info we have available for the new phone models but i can't find that information on those new models, sorry
maybe in the future it will be available
java
816
