POE Solution
I have a situation where a customer has recently purchased new 3560s, but not POE models. He now wants to put in 50 7960 phones, but without purchasing new switches. What's the best solution here? I have to provide a few hours of power backup, so I want to limit the number of power cords, and I need a solution that works with 7960 (pre-standard PoE).
Hall of Fame Super Gold
Re: POE Solution
check the following for a discussion on this exact subject, including multiport POE injectors:
http://www.voip-info.org/wiki-Cisco+POE
Re: POE Solution
Thanks for the suggestion, however I'm not concerned with converting the pre-standard to IEEE POE, but rather with one that will:
1. Limit the number of Power Cords, so I can easiliy provide power backup.
2. Use the existing 3560 non-POE switches.
I imagine the best solution would be a POE patch panel that supports pre-standard POE. Any opinions or product suggestions?
Re: POE Solution
Hi, as I said the product suggestions are in that thread, I'm not mentioning the brands or models here as this forum is mainly focused on cisco issues.
Hall of Fame Super Red
Re: POE Solution
Hi Aaron/Paolo,
Excellent info Paolo (as always) :) I don't think Cisco will mind if we refer Aaron to the following links (Cisco Partner) be sure to look at the secondary splitter required for the 7960 pre-standard PoE.
PowerDsine 6000 Power over Ethernet Midspan Family
http://www.powerdsine.com/Products/Midspan/PD_6000.asp
Good chart that shows 7960 etc.
http://www.powerdsine.com/Partners/Cisco/solutions.asp
Hope this helps!
Rob
286
