PoE switch selection
michaelzhq
Level 2
Level 2
What are the major differences between 3750-E PoE and 3560-E PoE switch? What is the reason to select one instead of another? Thanks.
paolo bevilacqua
3750 supports an high speed stacking connection, 3560 does not.
If you are looking for low cost PoE switches, get the 2960 PoE version.
Rob Huffman
Hi Michael,
Just to add a note to the good tips from Paolo, the videos below are pretty good and explain many of the differences;
Cisco Catalyst 3750 & 3560 Series Switches Video Data Sheet
http://www.cisco.com/en/US/prod/switches/ps5718/ps5528/3750_3560_video_data_sheet.html
Cisco Catalyst 3750 Series Switches
Data Sheets
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_data_sheets_list.html
Cisco Catalyst 3560 Series Switches Data Sheet
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
Cisco Catalyst 3560 and 2960 Compact Switch Video Data Sheet
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/product_data_sheet0900aecd806d5717.html
Hope this helps!
Rob
