Community Member
POE to 7914
Hi all. Im trying to hook up a 7914 to a 7960 phone powered via POE. At this point, I dont have a separate power supply for the 7914. Is there a way to power it via POE, like the phone?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: POE to 7914
Hey Guys,
I have always had to use the Power Cube even for 1 - 7914 if the 7900 series phone was using PoE.Here is the breakdown I have always used;
Cisco Unified IP Phone Expansion Modules 7914
Cisco 7960 Power Source
Items to Order
1 7914 with 7960 with In-line PoE (you need to order the following)
One, Cisco Unified IP Phone Expansion Module 7914
One, single footstand
One, power cube
One, country cord
1 7914 with 7960 with Local power (cube)* (you need to order the following)
2 7914's with 7960 with In-line or local power** (you need to order the following)
Two, Cisco Unified IP Phone Expansion Module 7914 ExpansionModule
One, double footstand
One, power cube
One, country cord
* A single Cisco Unified IP Phone Expansion Module 7914 can receive power from a locally-powered (power cube) Cisco Unified IP Phone.
** Local power must be connected to the first Cisco Unified IP Phone Expansion Module 7914. This supplies power to both Cisco Unified IP Phone Expansion Modules 7914s.
From this excellent doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_data_sheet09186a008008883d.html
Hope this helps!
Rob
Hall of Fame Super Gold
Re: POE to 7914
Hi, you should be able to PoE the first sidecar, but not the second. Then your luck can vary depending by the switch, does it work ?
Re: POE to 7914
Hey Guys,
Items to Order
One, power cube
One, country cord
One, power cube
One, country cord
Hope this helps!
Rob
Community Member
Re: POE to 7914
Well, Rob is correct in my situation. POE does power the phone, but not the sidecar. Just read the following, but I did see something in a cisco document that gave me the impression that POE would do it, although I cant find it now. Thanks all:
Procedure
Step 1 Depending on how your Cisco IP Phone 7960 is powered, perform one of the
following actions:
• If your Cisco IP Phone 7960 is powered over the Ethernet and:
- you have one expansion module, then connect the power supply unit to
the AC adaptor port on the expansion module and plug the other end into
a standard electrical power outlet in the wall.
or
- you have two expansion modules, then connect the power supply unit to
the AC adaptor port on the expansion module closest to the IP Phone and
plug the other end into a standard electrical power outlet in the wall.
• If your Cisco IP Phone 7960 is powered with a power supply unit and:
- you have one expansion module, then reconnect the original IP Phone
power supply unit to the AC adaptor port on the IP Phone and plug the
or
- you have two expansion modules, then connect a second power supply
unit to the AC adaptor port on the expansion module closest to the
IP Phone and plug the other end into a standard electrical power outlet in
the wall.
Re: POE to 7914
I stand corrected, I must have been confused by the situation where you have two modules and one brick only.
Community Member
Re: POE to 7914
Hey, I do have to say that there was some documentation that led me to believe that as well. Again, not sure which document I saw it in, but it did sound that way. Anyway, thanks you guys for helping.
Re: POE to 7914
Hi John/Paolo,
John, first off you are most welcome! Paolo, I thought that the 1st module could be powered via the phone PoE as well, and have read that in docs here before. This doc is the only accurate one that I have found for this :)
Take care Guys,
Rob
PS: Paolo, I read your NetPro interview today. Really great stuff and much deserved accolades my friend!
Huff
Community Member
Re: POE to 7914
Guys, thats one thing I should do more often is read the NetPro interviews of folks in here.
Paolo, I too, am impressed. Impressed with you too Rob. Thanks for all of the guidance you guys give.
Community Member
Re: POE to 7914
Paolo is right,
in many of my installation i never needed power cube for one 7914.
Good day
Community Member
Re: POE to 7914
Was there any special setup you had to do? Or what kind of switch was doing the POE?
Community Member
Re: POE to 7914
not really, only 3560 POE.
Good day
815
