Polycom ip 331 soundpoint with CUCM
Hello ,
Is it possible to configure a polycom ip phone directly in callmanager 8.6 and get it registered ? For example as a basic sip phone.
When i read the polycom integration guide there is not much information.
Kind regards,
Kurt
Everyone's tags (4)
Blue
Yes as Polycom supports SIP protocol and Cisco CUCM supports SIP protocol, you can regester it as third party SIP phone in Cisco CUCM.
Procedure of Adding third party phone in CUCM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_0_1/ccmcfg/b09sip3p.html
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hello Ronak,
Thx for the response. @cisco side it's indeed easy but on the polycom phone I can't add the authorization id (digest user).
Via cucm sip debug I can see that the phone tries to register but the phone sents request without digest user.
I filled in all the values in the polycom phone as 2000 (same as line number) but digest user stays empty.
Do you have any experience on the polycom phone configuration?
Kind regards,
Kurt
You need Minimum firmware version polycom phone : 4.0.2 (before 4 no digest authentic)
This is the solution.
Kurt
i have a similar problem.
i have a similar problem. Polycom phones of the same version with the same configuration one is working the other is not working. the non working one is not exchanging the digest credentials with the CUCM. All the phones have software versions below 4. there is phone with version 3.1.3 that is working another of the same is not working. there is another phone with software version 3.0.3 is working another with the same version not working.
send me the document you refered to amunagah@Hotmail.com
HTH,
HTH,
The problem I'm having is
The problem I'm having is that CUCM is configured and the phone works fine but I can't dial extensions. I can call outside and inside numbers using the full number i.e 6104567890 but if I just dial 7890 on the polycom soundpoint ip 331 it says your call can't be completed as dialed. Did I miss somethign? Also this guide does it include how to setup the exention portion of it?
You might be missing
You might be missing appropriate partition/CSS assignment... Did you check device CSS on Polycom phone?
- Vivek
I'm not 100% sure I just used
I'm not 100% sure I just used what was already in there. Where can I find this at? Thanks so much for replying.
Please check on the Device
Please check on the Device page on which respective Polycom phone is configured. You will get the parameter 'Calling Search Space'. Please ensure this CSS sees the partition where 7890 number resides.
- Vivek
Ok Rerouting Calling Search
Ok
Rerouting Calling Search Space has the CSS that my Cisco phone is on.
Subscribe Calling Search Space has <None>
If these are correct how can I tell if the actual number is inside these? I can page this polycom phone fine from one of my Cisco 7945's but I just can't page from the Polycom to anything else. Also will I have to make a new search space?
Check the following;1.
1. Partition assigned to DN 7890
2. You don't need to check rerouting and subscribe CSS. Please go to Polycom device page (Under Device) and check what value is set under 'Calling Search Space'. Ensure CSS configured here has access to DN 7890 partition.
You need to make new CSS or not depends on your requirement.
- Vivek
Awesome I can dial but one
Awesome I can dial but one last thing. If I dial 7890 it gives me a beeping noise both when I use speaker or pick up handset. BUT if I wait say 5-10 seconds it then goes through. Whats this? Is it somethign to do with the digitmap on the phone or a setting on CUCM?
If you don't have a answer
If you don't have a answer for above I think it might just have been CUCM syncing settings with the polycom phone because now it does it every time. I moved the CSS to one that was labeled Internal Only
Phone might be taking time to
Phone might be taking time to outdial because this is third party SIP phone and it will be having its own inter digit timeout. Please check phone configuration of polycom and shorten the digit time value.
- Vivek
Hello Kurt,
I need to connect also a Polycom IP 331 to CUCM but I have some problems, can you please share the information how you solved this issue.
Juan Carlos
I have this procedure described in a word doc. can you give me your email address?
Can't find the attach button in the forum ;-)
Kr,
Kurt
Of course Kurt, please share this document to my email address juancarlos.arias@monarch.com.mx
I'll appreciate all of your help.
Juan Carlos
Hello Dears, I have the same
Hello Dears,
I have the same problem. can you please share the information or procedure?
My email addres is camilo.aguilar@tecnoera.com or camilo.aguilar@live.cl
Regards.
Camilo Aguilar
Hello Juan, This information
Hello Juan,
This information is in your mailbox.
Kind regrads,
Kurt
Hi Kurt,can you send this
Hi Kurt,
can you send this word doc to my email too?
chelomix2003@hotmail.com
please...
i have ip331.
thanks in advance
Michel
Can you send this document to
Can you send this document to me also (vicky3ms@gmail.com) please
Thanks!
May I have the word doc for
May I have the word doc for Polycom IP 331 to CUCM usage?
Helo,i have this problem too
Helo,
i have this problem too.
can you send me the procedure that you have in doc to my email?
thanks in advance
Michel
Hello, I also have same
I also have same problem, so can you pls send it to me also.
regds
Mahavir
Hi Guys,      Can you please
Hi Guys,
      Can you please share any finding against the SoundPoint 331 interoperability with CUCM? How can I get it registered, features that will not work (conference, pickup, transfer, moh, etc) and if fallback (SRST) can be reached also?
Tks in advance,
Alexsandro Reimann.
I'm planning to use them with CUCM 10.5.
We had a similar problem on a
We had a similar problem on a recent project where were integrating soundpoint 331 and other version on cucm 10.5 nothing that we tried worked until we upgraded the firmware of the Polycom phone. Yes you can configure polycom phone to register from the cucm only after upgrading the firmware to the latest version. The only feature that remember did not work was extension mobility it seems that was not supported. But auto registration, conferencing, forwarding and other features all worked.
Abdul,Do you remember if you
Abdul,
Do you remember if you're using fallback like SRST (voice registrar at gateway)? The server 1 option point to a DNS entry for CUCM cluster and Server 2 point to SRST IP Address?
Thanks a lot!
2691
