Polycom SoundPoint IP 330 and Cisco Call manager 6.0
I have a Cisco Call manager 6.0 and i would like to khnow if i can deploy Polycom SoundPoint IP 330 IP phones with it.
Thank you for help.
Houichi Nizar
Re: Polycom SoundPoint IP 330 and Cisco Call manager 6.0
Hi, What do you do?
i like to do the same. Pls. see the attch. I configured for this way, but not works.
Regards.
CMP
• Press the Menu Button
• Choose (3) Settings
• Choose (2) Advanced
• Password is 456
• Choose (1) Admin Settings
• Choose (2) SIP Configuration
• Select Server and add the IP Address of the Cisco Call Manager©
Confirm this selection and scroll down to Line1:
• Enter a Display Name
• Add the SIP Extension that was added within the Call Manager Menu as the Address
• Add the SIP Extension that was selected as the Username within the Call Manager User Menu as the Auth User ID
• Add the 5 digit Auth Password that was selected as the PIN Entry within the Call Manager User Menu.
• Optional add a Label that will be displayed next to the Line Key
• Press exit until the Prompt comes to save the Settings and the Phone will reboot after this.
Also make sure that the SIP Extension you use has a User ID setup in the Owner User ID and the Digest User in the Call Manager Settings
1225
