Poor speakerphone quality
Have a user that when on speakerphone his voice is garbled like he is underwater and if he picks up the handset its ok.  Swapped the 7965 phone out but new phone is doing the same thing.  Happens on both internal and external calls, codec is g711 and running 8.5 code on the phone.  Had him adjust the speaker volume but still the quality is bad, any ideas?
Re: Poor speakerphone quality
I dont recall the details for the bug ID but there was a bug for this behavior discussed not too long ago.  The fix, I believe, is a firmware upgrade.  What firmware are you currently running?
Hailey
Please rate helpful posts!
We are running SCCP45.8-5-2S.
I have looked through the bugs but did not find anything for this load.
Tina
Hall of Fame Super Red
Hi there,
Hailey is most correct here (+5 points my friend!)
Here is the related bug;
CSCsz68389 Bug Details Bug #8 of 8 | <            Previous | Next >
Noise Reduction causes saturated speech on Handsfree  Send
Symptom:
When talking on the speakerphone, far end  listeners may hear voice clipping. The talker's voice may sound like a  buzz.
Conditions:
This issue is most  noticeable when the talker is using the speakerphone on 7931, 7962,  7965, 7972, 7945, and 7975 models. This defect only applies to these  phone models.
Workaround:
The talker can sit  farther away from the phone, talk in a lower voice or use the handset or  headset.
Further Problem Description:
If User A  calls User B on User A's speakerphone, then User B would hear scratchy  sounding voice
StatusStatus
Fixed
Severity Severity
3 - moderate
Last Modified Last Modified
In Last 2 weeks
Product Product
Cisco Unified IP Phone 7900 Series
Technology Technology
1st Found-In 1st Found-in
8.5(2)
Fixed-In Fixed-in
8.5(2)CA1.2
8.5(3)MN1.8
8.4(4)ES7
6.1(4.39000.84)
6.1(4.1107.1)
5.1(3.7108.1)
7.1(2.22010.1)
7.0(2.22027.1)
6.0(1.3125.1)
6.1(3.3217.1)
4.3(2)ES18
4.3(2)SR2
6.1(5.10000.10)
Cheers!
Rob
Rob - yeah this looks like my problem.  I'll trying upgrading and
see if it resolves the issue.
Tina
463
