Port not available to be added to route group
kylebrogers
Level 4
Level 4
CUCM 9.1.2
I have a 2911 (MGCP) with an FXO card.  The FXO port is configured and shows as registered but will not show up in the ports list in my route groups so that I can add it.  Every other port from my other MGCP gateways shows up fine.  Resetting the port and having it re-register did not help.  Any ideas?
George Thomas
Level 10
Level 10
If the port is assigned to a route pattern, it wont be an option available under Route groups and vice versa. I would check depending records on the ports to see where its assigned and change it.
Please rate useful posts.
George Thomas
Level 10
Level 10
That was it.  There was a pattern pointing directly at the port.  As soon as I changed the pattern to point to a RL instead, the port showed up in the RG list.  Thanks.
