Port registration rejected on VG224 using MGCP
I am trying to setup a VG224 to replace the large bank of ATAs I have collected for faxing. When I do a sho ccm I see the VG224 is registered. Looking in UCM 6 I see the individual ports showing Registration Rejected.
Here is the config I am running:
chvg224#sho run | b mgcp
ccm-manager mgcp
ccm-manager config server 10.4.1.10
mgcp
mgcp call-agent 10.4.1.10 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
1 REPLY
Re: Port registration rejected on VG224 using MGCP
Make sure the device you set up in Call Manager is called "chvg224" or, if you have a domain name in your router config, "chvg224.yourdomain.com". Though, by your symptoms, it looks like you got that far already.
Also, to have your dial peers created automatically, you may add "ccm-manager config", otherwise create them manually and add the "service mgcpapp" command under each one.
2408
