Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
possibility of usage FAX over IP with Unity Connection
I have some questions. Can anybody answer for them in the asked order?
1)What adventages will I reaceive with integration Unity Connection and CUCM?
2)Could I integrate Unity Connection 7 and CUCM 6.1?
3)Could I use Unity Connection for sending/receiveing fAXes by mail?
Thank you!
Re: possibility of usage FAX over IP with Unity Connection
Ans: Unity Connection is a great tool for VoiceMail/Unified Messaging as well as it functions pretty well as an Auto Attendent
Ans. Yes, we have one of our clients in the same configuration.
3.Could I use Unity Connection for sending/receiveing fAXes by mail?
Yes, however you need to integrate it with a Fax Server
You may find this guide helpful:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/design/guide/7xcucdg080.html
Hope that helps, please rate if it helps
Sam Wilson
Can I send FAXes to mailboxes without using/buying additional servers like FAX Server?
151
