tka
Community Member
Possibility to implement a MoH source on an SRST router
Hi ,
Assumin we have a centralized CUCM deployment, in order to save bandwidth, Is it possible to implement an MoH source on a SRST router. The source should be utilized all the time not only when the WAN is down.
best regards,
1 REPLY
Re: Possibility to implement a MoH source on an SRST router
Yss, you could have easily searched SRST + MOH in CCO instead and this is the 1st match
Integrating Cisco Unified Communications Manager and Cisco SRST to Use Cisco SRST as a Multicast MOH Resource
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/srst/configuration/guide/srs_moh.html
You could have also searched NetPro and get a lot of hits on the topic
java
if this helps, please rate
java
www.cisco.com/go/pdi
148
