Possible CallManager 6.0 Issue
Hello All,
I have a VG 224 for my analog devices. I need to setup one of the 23 channels for EXT 2222 in Call Manager 6.0. I assigned the Extension under the gateway tab in Call Manager 6.0. I selected the VG 224 in Call Manager I then went to configure port 19. I clicked on Line and entered my EXT number there and clicked save and reset. However when I go to the analog phone and try to dial a internal EXT or any Ext I get dial-a-tone and a fast busy. I am having the guy that punched the cable down on port 19 on the 66 block to confirm he really did punch the cable down on the correct port. Am I doing something wrong?
2 ACCEPTED SOLUTIONS
Re: Possible CallManager 6.0 Issue
What protocol are you using for the VG224? MGCP or SCCP?
Do you have the dial-peer on the VG224 configured correctly for the selected protocol?
MGCP Example:
dial-peer voice 999219 pots
service mgcpapp
port 2/19
SCCP Example:
service stcapp
port 2/19
Also, just because I have had techs do this before, VG224 port numbering starts at 0, so you need to make sure you are connecting to the correct port.
Adam
Please rate if helpful
Hall of Fame Super Red
Hi Charlie,
Just to add a note to the excellent info from Adam (+5 points here Adam :)
Please try to use this method to completely remove the DN in question before trying to re-build again.
**Remove DN xxxx (the one that was previously used on the IP Phone) from the phone first;
Deleting Unassigned Directory Numbers
This section describes how to delete an unassigned directory number from the route plan report. Directory numbers get configured and removed in the Directory Number Configuration window of Cisco CallManager Administration. When a directory number gets removed from a device or a phone gets deleted, the directory number still exists in the Cisco CallManager database. To delete the directory number from the database, use the Route Plan Report window.
Procedure
Step 1 Choose Route Plan > Route Plan Report.
The Route Plan Report window displays. Use the three drop-down list boxes to specify a route plan report that lists all unassigned DNs.
Step 2 Three ways exist to delete directory numbers:
a. Click the directory number that you want to delete. When the Directory Number Configuration window displays, click Delete.
b. Check the check box next to the directory number that you want to delete. Click Delete Selected.
c. To delete all found unassigned directory numbers, click Delete all Found Items.
A warning message verifies that you want to delete the directory number.
Step 3 To delete the directory number, click OK. To cancel the delete request, click Cancel.
Once you have completed this process add the DN xxxx back to the phone again (**check the Calling Search Space) and try again.
Hope this helps!
Rob
MGCP Example:
service mgcpapp
port 2/19
SCCP Example:
service stcapp
port 2/19
Adam
I am using MGCP. Also the EXT I and using for this analog phone was taken from a IP Phone that is no longer being used on our network. That should be ok right.
Thanks for solving my problem. I can belive they punch that down wrong. I will make sure that does not happened again. Thanks again. Everything is working Flawless now.
Hi Charlie,
Procedure
Hope this helps!
Rob
139
