Possible to disable a switchport if no Cisco phone is detected?
Is there a Cisco access switch feature to disable a switchport if a device is attached directly to the port and it is not a Cisco phone?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Possible to disable a switchport if no Cisco phone is detect
How? Can you give an example?
Here's a good explanation about AutoSmartPort:
Configuring Auto Smartports Macros
you want to disbale from POE power that it is giivng when plug up ip phone
if you are plugging nay non ip phone device, for saving part use the commands:
under switch interface:
#int fa 0
# no poe power
exit
please check the commands for this aprt under interface.
Warm Regard's =========== Amit
247
