Possible to remove blinking envelope from phone ?
mcdonovan
Hi, Is it possible to disable the blinking envelope displayed on phones when a new message arrives? Could not find anything on this.
Unity version 7.0(2.0)
Back end is Domino server WWMAIL02
CM version: 7.0.2.20000-5
6 Replies 6
Brandon Buffin
You can, but it would also disable the red MWI light that indicates a new message. You can do this per subscriber by going to Unity web admin > Subscribers > Messages and uncheck "Use MWI for message notification." You can also change this for new subscribers by changing a subsriber template or you can use Bulk Edit in the Unity Tools Depot to change multiple existing subsribers.
Hope this helps.
Brandon
Rob Huffman
Hi Mike,
Just to add a note to the good tips from my friend Brandon (+5 points here Brandon)
You can also play with these settings under the DN Config page in CUCM
Line Settings for this Device - Changes affect only this device
Message Waiting Lamp Policy
Use System Policy
Light and prompt
Light Only
Prompt Only
None
Interestingly enough, you can remove the text prompt or the RED lamp but not the Envelope icon alone :)
Hope this helps!
Rob
Rob,
Good point. I didn't think about the DN settings. Interesting that you can remove the other prompts, but not the envelope.
Brandon
Great info. Five points to you both. I suppose there is no way to turn off the blinking envelope for just one line on a phone? We have a shared DN on the 3rd line display of 22 phones that lands on a group VM box in Unity. This is the line in we want to remove the blinking envelope from.
Yes, you can turn it off for this DN on a particular phone as Rob indicated or you can turn off MWI for this mailbox in Unity.
Hope this helps.
Brandon
Perfect. Thanks!
