Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Postage machine with VG202
I've read all the posts but haven't seen any clear signs of success with being able to get a VG202 to work with a postage machine.
Of course, fax machines work without any issues but it's just with the postage machine.
The postage machine we're using is a CentorMail. The devices seem to get connected but then the call is dropped.
The VG202 has 15.1 on it and CallManager is 8.6
Call flow: Postage machine - VG202(Port 0/0)- H323 - CUCM 8.6 - H323 - 3900 VG w/ PRI - ISDN provider
VG202 config
stcapp register capability 0/0 modem-passthrough
stcapp ccm-group 1
stcapp
stcapp supplementary-services
 port 0/0
  fallback-dn 1998
 port 0/1
  fallback-dn 1997
voice service voip
 fax protocol pass-through g711ulaw
 modem passthrough nse codec g711ulaw
voice-card 0
archive
 log config
  hidekeys
interface FastEthernet0/0
 ip address 192.168.1.2  255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
control-plane
voice-port 0/0
 input gain 6
 output attenuation 10
 timeouts initial 60
 timeouts interdigit 60
 timeouts ringing infinity
voice-port 0/1
ccm-manager sccp local FastEthernet0/0
mgcp profile default
sccp ccm 10.2.40.12 identifier 1 priority 1 version 7.0
sccp ccm 10.90.50.12 identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
dial-peer voice 1 pots
 service stcapp
 port 0/0
dial-peer voice 2 pots
 service stcapp
 port 0/1
line con 0
 exec-timeout 0 0
 login local
line aux 0
 login local
line vty 0 4
 login local
 transport input all
Everyone's tags (3)
1 REPLY
Hi.I suggest you to configure
Hi.
I suggest you to configure a voip dialpeer on your 3900 VG with answer-address option to match calling number  of VG202 port and set modem passthrough option.
Eg.
DN configured on VG port :5900
dial-peer voice XX voip
answer-address 5900
codec g711ulaw
dtmf-relay h245-alphanumeric
no vad
Carlo
Please rate all helpful posts "The more you help the more you learn"
134
